Thread: What Amp Do I Choose? |
New member Username: Dan3d86
Reading England
Post Number: 1 Registered: Aug-04
| Posted on Thursday, August 05, 2004 - 04:20 pm: |
im looking at buying the sony XSL121P5 sub, can anyone help? i dont know what kind of amp to get to power it? |
Bronze Member Username: Sixstar
Post Number: 13 Registered: Aug-04
| Posted on Thursday, August 05, 2004 - 04:32 pm: |
Okay, first off, how much are you willing to spend on the whole system? Secondly, what are our chances of managing to convince you NOT to buy a Sony car audio product? |
Reading England
Post Number: 2 Registered: Aug-04
| Posted on Thursday, August 05, 2004 - 04:41 pm: |
Im guessing you wouldn't reccomend a sony car product ? Im not sure on money, its just iv seen the 12" sub for 50 quid thats why i was interested. |
Post Number: 14 Registered: Aug-04
| Posted on Thursday, August 05, 2004 - 04:52 pm: |
Well, they aren't the worst products, they are decent. The sub in question is cheap, so it isn't overpriced for its quality. The problem with it is more that it is a 4 ohm voice coil, and running 300 watts into 4 ohms is going to cost you quite a bit of money. Do they have a 2 ohm voice coil version? |
Silver Member Username: Jonathan_f
GA
Post Number: 958 Registered: May-04
| Posted on Thursday, August 05, 2004 - 05:42 pm: |
Sony is better than all of the following brands... 1) 2) 3) 4) 5)pyle 6)legacy 7)boss 8) 9) 10)road gear 11) 12)funky pup 13) 14) Seriously, though, I would recommend that you look into Kicker Comps or Comp VRs, maybe Adire Audio Shivas, Cerwin Vega V-Maxes, there are many better subs out there. |
New member Username: Koz1031
Monticello,
In
United states
Post Number: 7 Registered: Jul-04
| Posted on Thursday, August 05, 2004 - 08:16 pm: |
if you haven't bought them yet let me assure you listen to these guys. I wish I had found this site before I bought mine. Sq and SPL just isn't there. They sound like dodo and don't really get that loud. I agree with Jonathan, I'm getting ready to replace the sony's with the Adire shivas. Not sure how much a quid is but $125 is a great price for those subs but then I might go the rockford fosgates. |
Silver Member Username: Iamduff_87
Michigan
America!
Post Number: 182 Registered: May-04
| Posted on Friday, August 06, 2004 - 12:26 am: |
also i am in the same boat as KOZ. got some Sony subs before i knew what i was doing. now im upgrading probably to 1 Shiva in a 1.6cu ft sealed box with a Kicker 350.2. This setup is mostly a SQ setup. Hope it works awsome. |
