Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Power needed
Author Thread: Power needed
Username: Tallywhacker
Here is my plan let me know what you all think:
(btw it is for a 04 gmc Yukon)
2- JL 10w6v2's with JL1000/1 amp
JL XR650 CSi in front
Boston Neo 3r tweets for imaging
What sized JL amp should I run for these components and extra tweets?
Also front doors will be dynamatted
and there are no plans for a HU yet.
Please give me some input on my selection
thanks guys!
what JL amp do you guys suggest
Username: Sixstar
Post Number: 15
Please don't have a heart attack if no one answers your message in 4 hours, geesh.
The JL 300/4 would be good I think. get 75 to each of the CSi's, and then bridge the remain two channels, and give that to the tweeters (they are 8 ohm, 20-100 RMS, right?). Im not quite sure if that would work. Why so you NEED a JL amp?
I just want to keep everything consistant. yea they are 8ohms and 20-100rms. What do you think about the Boston Pro60 when comparing them to the XR's?
Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Power needed [ « Previous ] [ Next » ]
