Thread: Alternator |
New member Username: Wayne230e81
Germany
Post Number: 9 Registered: Jul-04
| Posted on Thursday, August 05, 2004 - 02:16 am: |
My car is a 1981 Mercedes-Benz 230E. It has a 55amp alternator. I have a Crossfire CFA602 and I think this amp is sucking up more amps than the alternator can put out. Is there any way to increase the output of the alternator by having a proffesional adding more copper to it? Or do I need to buy I new one? If I do buy a new one, where would I buy one and how much? |
Silver Member Username: Jayj
Louisiana
Post Number: 403 Registered: May-04
| Posted on Thursday, August 05, 2004 - 02:47 am: |
Your best bet would be too buy a new alternator. About 100amps should be enough. Good Luck |
Louisiana
Post Number: 404 Registered: May-04
New member Username: Bandit8623
Rochester,
Minnesota
Us
Post Number: 8 Registered: Aug-04
| Posted on Thursday, August 05, 2004 - 03:03 am: |
go to napa or checker any major auto place rebuilds them |
