Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Help with squeal
Author Thread: Help with squeal
klm0n
Here is the scenario:
- pioneer head unit with RCA frnt and rear outputs hooked up to phillips amp in trunk, which in turn is hooked up to the frnt door speakers and rear-deck speakers
- amp is directly conected to the battery in the trunk (by 12 gauge wire and fuse)
- speakers in the rear doors are connected directly to the head unit
- The (loud) squeal occurs when both RCA channels are connected to the amp
- if I unplug one or the other channels from the amp the sound disappears
- It seems that the two RCA circuits are interfering with each other
- Will rewiring the RCA connection so both channels have a common '-' wire (correct the problem?
Thanks
Ple
anyone?
Username: Jeremyc
Kunsan Afb
South Korea
Try swapping out the amp. Just borrow a friends and slave it in. I bet the amp is causing the problem.
Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Help with squeal [ « Previous ] [ Next » ]
