Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Alternator noise????????/
Author Thread: Alternator noise????????/
Jerrry0n0
Hi,
I'm new to the site and have a question.
Here is the scenario:
- pioneer head unit with RCA frnt and rear outputs hooked up to phillips amp in trunk, which in turn is hooked up to the frnt door speakers and rear-deck speakers
- amp is directly conected to the battery in the trunk (by 12 gauge wire and fuse)
- speakers in the rear doors are connected directly to the head unit
- The (loud) squeal occurs when both RCA channels are connected to the amp
- if I unplug one or the other channels from the amp the sound disappears
- It seems that the two RCA circuits are interfering with each other
- Will rewiring the RCA connection so both channels have a common '-' wire (correct the problem?
Thanks
JK
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 8
Try a diffrent amp, sounds like it is fried.
Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Alternator noise????????/ [ « Previous ] [ Next » ]
