Thread: Amp and Box for 1 Shiva |
Silver Member Username: Iamduff_87
Michigan
America!
Post Number: 175 Registered: May-04
| Posted on Wednesday, August 04, 2004 - 03:09 pm: |
Hi I am looking into getting 1 12" Adire Shiva. I have looked into all of the amps and can find a Kicker KX350.2 350RMS Alpine MRV-T420 340RMS MTX Thunder 342 340RMS all of these would be around $140 or so. They would all run that power at 4ohms since Shivas are dual 8 ohm. Which amp would you choose and why. Also I was wondering what kind of box I should get for the best sound quality. Size shouldnt be an issue with only 1 12" as long as the box doesnt get over 2.5 - 3ft cubed. How much would the best SQ box usually cost for this 1 sub? |
Michigan
America!
Post Number: 176 Registered: May-04
| Posted on Wednesday, August 04, 2004 - 03:11 pm: |
Also I was looking into a JL 250/1 but could not find one under $280 or so and I do not feel like spending 2x as much if the other amps will do the same. If you think this amp is worthy of 2x the price then please tell me why. Thanks. |
Silver Member Username: Jonathan_f
GA
Post Number: 940 Registered: May-04
| Posted on Wednesday, August 04, 2004 - 04:02 pm: |
All are great amps, I'd go with the Kicker in the end. 2 channel amp, great sound quality and a solid amp, it would push the shiva well. |
New member Username: Sixstar
Post Number: 3 Registered: Aug-04
| Posted on Wednesday, August 04, 2004 - 06:14 pm: |
You obviously aren't buying htem retail, but here are their prices retail: Kicker- $379 Alpine- $399 MTX-$299 JL-$399 So they are all in the same ballpark (minus the MTX). JL is probably the best one, but I guess the markup on Kickers is greater, thats why you can find a better deal. Id do what Jonathan said, go with the Kicker, it'll be damn fine. |
Michigan
America!
Post Number: 178 Registered: May-04
| Posted on Wednesday, August 04, 2004 - 07:28 pm: |
of course they are not retail. i dont have the money to buy them retail LOL. the prices are from various places Kicker - thewholesalematrix.com Alpine - discountjungle.com MTX - acaraudio.com all 3 can be found for a little less or the same NEW on ebay. none of these prices had shipping. but about the box. what box type would give the best SQ. i know the SPL will be less this way but im sure it will still be very loud. what kind and what size will give me the best SQ, and how much do they run at???? |
Silver Member Username: Sploosh56
Post Number: 319 Registered: May-04
| Posted on Wednesday, August 04, 2004 - 11:04 pm: |
I'd get the Kicker amp. Awesome amp for the money paid. |
