Thread: Kappa perfect 5.1/6.1 power query? |
New member Username: Beek
Post Number: 6 Registered: Jun-04
| Posted on Sunday, August 01, 2004 - 07:00 am: |
I am currently running a pair of 6x9's in my rear shelf and co-axial door speakers in the front. I've browsed through the forum and noticed that the majority of u guys recomend using component speakers instead? What is the max power handling and rms for the kappa perfect component speakers? I have a 4 channel JBL PX300.4 600W max, 4 x 150w RMS amp. Would this be suitable for the Kappa perfect components up front, with 150w RMS 6x9's at the rear? Any help would be much appreciated! |
Silver Member Username: Mattl
Bolingbrook,
Illinois
Post Number: 337 Registered: Jun-04
| Posted on Sunday, August 01, 2004 - 08:01 am: |
That is within tolerance, but leave any gain adjustments flat. -Matt |
Post Number: 7 Registered: Jun-04
| Posted on Sunday, August 01, 2004 - 09:07 am: |
Thanks for the reply matt. Ive just realised that the amp is rated: 150w x4 rms at 2 ohms but only 75w rms x 4 at 4 ohms, but the amp should still be capable of running them at 4 ohms shoudn't it? Also... ive heard that its best 2 just run components in the front and ditch the 6x9's in the rear for better sound staging. Is this correct? (I am running a sub in the back) |
Bolingbrook,
Illinois
Post Number: 342 Registered: Jun-04
| Posted on Monday, August 02, 2004 - 07:14 am: |
On the amp side, you're going to be fairly underpowered. I would recommend that you consider selling that one on eBay and getting one with appropriate power. Regarding the staging, yes, ditching the rears will improve your sound. We really don't recommend them around here unless you're absolutely going to be carrying rear passengers. -Matt |
