Thread: Eclipse Amps |
Chippa |
| Posted on Wednesday, December 03, 2003 - 08:31 pm: |
Any comments or opinions on Eclipse 4-channel amps?? I have the Eclipse 36401 (50Wx4) currently and it sounds very good. I may be looking to upgrade in the near future, mainly because I'm never satisfied, lol. But anyways, should I stick with Eclipse or are they other amps that sound way better, that I might not know about. Eclipse and Power Acoustik(not good) are the only 4-ch amps I've had in my car. I've never really heard any others. What are some good Quality 4-ch amps??? Im looking to stay in the $300 range. |
Chippa |
| Posted on Thursday, December 04, 2003 - 04:39 pm: |
Any help. please??????????? |
| Posted on Monday, December 08, 2003 - 11:34 pm: |
eclipse is probably the cleanest you'll get for mids and highs, just make sure your fedding them a solid 8 volt preout from either an eclipse head unit, or I ran mine through an audio control line driver. If the amp "sees" 8 volts or something close in the RCA's, then you will be impressed, and probaly is unmatched in clarity- so just invest that $300 in an audio control dsp equalizer or somthing similar, after that, you'll have competition ready mids and highs. check www.audiocontrol.com |
| Posted on Tuesday, December 09, 2003 - 07:10 am: |
Eclipse makes very good amplifiers, utilizing dual toroidal transformers. Good build quality. If you want alternatives: JL Audio 300/4 Kicker KX300.4 Sinfoni AMPLItude 120.4x Zapco (zapco dot com) several models |
K,L WATSON Unregistered guest |
| Posted on Thursday, December 25, 2003 - 10:20 pm: |
i've got 6 12 inch dual-voicecoil 4ohm kicker comp cvr subs.i'm trying to use an red orion hcca 2100 to push them.i haven't found an audio shop here in j-ville,fl that can make this amp reach it's full potential.i'm accepting advice from anyone who knows about this old amp |
| Posted on Thursday, December 25, 2003 - 10:32 pm: |
MY MAIN CONCERN IS GETTING FULL POWER OUT OF THE AMP WITHOUT FRYING IT. I'LL EITHER ADD OR SUBTRACT SUBS TO GET THE PROPER OHM LOAD I ALREADY HAVE A POWER-LINE 250 AMP ALTERNATOR 2 1-FARAD CAPS AND A YELLOW TOP BATTERY.I'VE ALSO GOT 4-GUAGE RAN TO THE TRUNK.IS THIS NOT ENOUGH? |
New member Username: Glasswolf
Post Number: 333 Registered: 12-2003
| Posted on Thursday, December 25, 2003 - 10:38 pm: |
use 4 of the 12" subs, if they are 4 Ohms per coil. wire the coils in parallel to get four 2 Ohm subs. place two subs in parallel on each channel of the 2100HCCA. that'll be a stereo 1 Ohm load, which is the max for that amplifier. great amp by the way.
| Posted on Thursday, December 25, 2003 - 11:04 pm: |
HEY, THANKS FOR THE ADVICE.IF YOU DON'T MIND,I HAVE ONE LAST QUESTION FOR YOU. HOW MUCH POWER WILL THE AMP DELIVER AT 1-OHM STEREO? |
| Posted on Thursday, December 25, 2003 - 11:12 pm: |
IF THERE IS ANYONE LOOKING TO PURCHACE AN ORION 2100 HCCA,I KNOW WHERE TO FIND ONE.IT'S LOCATED IN JACKSONVILLE,FL. AT A NORTHSIDE PAWN SHOP BY THE NAME OF DUNN PAWN.THE PHONE NUMBER THERE IS AREA CODE 904-751-3006.JUST ASK FOR TECHNICIAN MIKE |
Post Number: 344 Registered: 12-2003
| Posted on Friday, December 26, 2003 - 03:03 am: |
Orion 21--HCCA: 100wRMS x 2 @ 4 Ohms Stereo @ 12VDC 200wRMS x 2 @ 2 Ohms Stereo @ 12VDC 400wRMS x 2 @ 1 Ohm Stereo @ 12VDC you'll get 200wRMS per sub.
