Thread: Hard hits make lights dim, how do I fix this |
Bronze Member Username: Boopers
Lima,
Ohio
United states
Post Number: 27 Registered: Jul-04
| Posted on Thursday, July 29, 2004 - 11:39 pm: |
I'm sure this is a common problem, but not sure how to fix it, since I got my bigger sub when it hits my lights dim. Is this an easy fix or do I have to look at somewhat major mods to avoid killing my altenator |
Bronze Member Username: Southernrebel
Louisiana
Post Number: 100 Registered: Mar-04
| Posted on Friday, July 30, 2004 - 12:00 am: |
a new alt. is the only true "fix" most likly...what size is your stock alt. and what amp do you have??? |
Lima,
Ohio
United states
Post Number: 28 Registered: Jul-04
| Posted on Friday, July 30, 2004 - 12:05 am: |
have no idea on the stock alt, but the amp is only a little 760 pioneer, wouldn't think that would stress my stock alt though |
Lima,
Ohio
United states
Post Number: 29 Registered: Jul-04
| Posted on Friday, July 30, 2004 - 12:19 am: |
ALTERNATOR 6 3.8 231 1 All 20-1159-31 DR CS144 140 info I got on my alt, guessing 140 is the size or whatnot |
Silver Member Username: Purplehase_bong
Bc
Post Number: 117 Registered: Apr-04
| Posted on Friday, August 06, 2004 - 01:11 am: |
well stock alternators put out about between 90-110amps. but it shouldent be a big problem tho.! |
