Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Fosgate p3002 good enough?
Author Thread: Fosgate p3002 good enough?
helpplease
will this fosgate punch p3002 amp be enough power for a premier 12 inch sub model #TS-W125C/DVC
Username: Pdivvy5
CT
United States
Post Number: 24
You should be good. My friend has this amp and he likes it a lot.
Username: Pat_l
Tucson, AZ
Post Number: 440
That will be plenty
Username: Phaseramous
Cudahy, Ca
Us
Post Number: 8
If you are interested I have a 2004 punch p8002 rockford fosgate amp with remote punch bass controller, I paid $600 for it but no longer need it since I got an 1100a2 fosgate and a 800a2 also. I am willing to sell it for $400, i tested the amp by bridging it and hooking up one 12' t1 1200 watt fosgate woofer and a 15' hx2 2000watt fosgate woofer and the amp lifted both with no problem. It is 800 at 4 0hm 1600 at 2 ohm's and 2400 peak at 1 ohm.
Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Fosgate p3002 good enough? [ « Previous ] [ Next » ]
