Thread: Amp won't work right |
New member Username: Jeff518
Post Number: 1 Registered: Jul-04
| Posted on Thursday, July 29, 2004 - 01:22 am: |
I just got a Jensen JXP720 car amp off ebay. I went to install it and the jensen logo lights up, as well as this "power protect" indicator light. but no music comes out of my subs. The subs are 2 12" Kickers which work fine. THESE ARE THE SPECS ON THE AMP. Total Peak Music Power: 720W Peak Power Per Channel @ 2 ohm: 360W x 2 RMS Power Per Channel @ 2 ohm: 180W x 2 Peak Power Per Channel @ 4 ohm: 260W x 2 RMS Power Per Channel @ 4 ohm: 130W x 2 Peak Power Bridged @ 4 ohm: 720W x 1 RMS Power Bridged @ 4 ohm: 360W x1 Variable input level controls Pass through RCA outputs Extruded aluminum heat sink Top mounted controls Oversize power/ground terminals Auto-reset thermal/short circuit protection Auto-reset Low impedance/DC offset protection Power/protect bi-color LED indicator Blue LED illuminated JENSEN logo PWM MOSFET power supply Complimentary bi-polar output transistors 2 Ohm stable (stereo operation) Tri-mode operation Bridgeable operation Selectable crossover (High pass/low pass/full range) Variable high pass crossover (40-400Hz) Variable low pass crossover (40-400Hz) 12dB/Octave crossover slope 12dB Variable bass boost @ 45Hz Remote bass control High level (speaker level) inputs 2V - 10V Low level (RCA) inputs 300mV - 8V What could the problem be here? And what exactly is the "pass through RCA outputs" I hooked my white and red RCA's up to both the input and also output, but still no music coming out my subs. Is this Power Protect light supposed to be on? |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 439 Registered: Apr-04
| Posted on Friday, July 30, 2004 - 07:56 pm: |
No the power protect light is not supposed to be on. I am almost positive that a 'pass through' is where you hook up the RCA's from the deck to the AMP then you can OPTIONALY hook up another set of RCA;s to the pass through and pass the same signal on to another AMP. Sounds like some thing is hooked up in the wrong spot. |
Post Number: 2 Registered: Jul-04
| Posted on Saturday, July 31, 2004 - 12:11 am: |
hey thanks for the reply, the power protect light comes on whenever I put power to the amp and attach the ground wire [with the ignition in the "on" position] even if i don't have the speaker wires or rca's connected. I took the cover off the amp and I'm wondering if there should be more inside the amp because all there is inside it is a big circuit board going the length of the amp with a few wires, I thought there would be more to it than this thin circuit board but maybe I'm wrong. I hooked up my old amp which is a Jensen 300watt and it works perfect. Would having too small of a power and ground wire make the power protect light come on? What else could trigger this power protect light, and can car stereo shops test amps to see what's wrong with them? |
| Posted on Saturday, July 31, 2004 - 01:01 am: |
hye supzzz ppll...i have one questions i got like 3 subs ....to 12'..max power 1200 wat each and one 10'.... 600 wat ....they are sony xplood wat amplifire will the best for them....can someone help me... plzzzzzzzzzzzzzzzzzzzz..... one more time please.... |
Post Number: 3 Registered: Jul-04
| Posted on Saturday, July 31, 2004 - 01:35 am: |
update: I tried hooking the amp up again with the same results, I'm pretty sure I got ripped off because even with the amp turned on and power on, if I pull the 2 fuses out of the amp it does nothing, the amp lights still stay on. I tried pulling the fuse out of my 300watt jensen and the amp shut off. so did I get ripped off? sure sounds like it to me |
New member Username: Koz1031
Monticello,
In
United states
| Posted on Saturday, July 31, 2004 - 05:59 am: |
did you buy a used amp? |
Post Number: 4 Registered: Jul-04
| Posted on Sunday, August 01, 2004 - 01:02 am: |
yea the amp is used, it only cost me $20 so I guess it's not that big of a deal really, anyone else care to put some input in here? does the amp sound broken to you, only thing inside it is a flat ciruit board and when I pull the fuses nothing happens. thanks |
New member Username: Bizziatchi
Post Number: 6 Registered: Apr-04
| Posted on Sunday, August 01, 2004 - 01:24 am: |
it sounds like a grounding problem. i had that happen to me. make sure the ground is secure, and scrape the paint off of the bolt, washer and whatever else is connected to the ground bolt. make sure you get as much paint off as you can. if its not that then im not sure what to tell you. hope this helps. get back to me and let me know. oh and make sure the fuses arent blown |
