Thread: 1997 Chevy Suburban |
FRANKANDBEANS Unregistered guest |
| Posted on Wednesday, July 28, 2004 - 10:25 pm: |
Has anyone ever installed the amplifier power cable in a 97 suburban, i need a guide of where to run it through the firewall. |
New member Username: Wreed
Post Number: 1 Registered: Jul-04
| Posted on Wednesday, July 28, 2004 - 10:29 pm: |
good question, hope someone can help |
Bronze Member Username: Donaldl396
Post Number: 14 Registered: May-04
| Posted on Wednesday, July 28, 2004 - 10:59 pm: |
Heres how I did my 99. My amp is located under the back seat behind the driver, this way it doesnt interfear with someone getting into the third seat. I ran my amp wire from the battery down along the underside following the aux heater and AC hoses. I removed the sill plate, its the black plastic trim piece you see when you look down on the passenger side rear door opening. Drilled a 7/16" hole, watch out for AC and heater hoses under the truck!, installed a rubber gromet and ran the wire under the carpet to the other side and slit a small hole for the wire to neatly come out of. |
Post Number: 2 Registered: Jul-04
| Posted on Wednesday, July 28, 2004 - 11:27 pm: |
i am intrested in this too, donald if you have a digital camera a couple of pictures would be nice! Thanks |
