Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through August 23, 2004 > Polk Componenents
Author Thread: Polk Componenents
inprogress
are the good my car came with them and they sound pretty good to me but didn't know if there is something better thats not too expensive??
inprogress
they are 5.25 w 1 inch tweeter
Username: Mattl
Bolingbrook, Illinois
Post Number: 322
Were they aftermarket Polks or a "premium sounds system" in the factory car? Do you know which models they are? Is there an amp?
-Matt
Username: Inprogress
Post Number: 15
no amp just running off hu ,pioneer, aftermarket polks
Username: Mattl
Post Number: 324
What kind of car? If it's a Honda, then that's probably about as good as you'll do without an amp.
-Matt
Post Number: 22
dx3055 in doors and on the opposit of my miror(tweeters) in a 2001 mustang
Post Number: 23
same component set is in the rear as well
Post Number: 36
good set ?it sounds good to me but I wanted to know how my hearing is compared to the pros or change it out? if change out with what?
Post Number: 40
opinions
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through August 23, 2004 > Polk Componenents [ « Previous ] [ Next » ]
