Home > Message Board > Car Audio > Amplifiers > Archive through August 03, 2004 > What amp for 12" visonik
Author Thread: What amp for 12" visonik
Username: Boopers
Lima, Ohio
United states
Post Number: 10
from earlier thread I have 12" Kenwoods now but am upgrading to 12" visoniks 6ohm dvc 600watt rms 1200 max, what would be the ideal amp for these, also thinking of doubling up and getting 2 more of these same speakers down the road
Username: Davids2004
Houston, TX
Post Number: 446
jbl 1200.1 or the kicker 1200.1. Those two subs are gonna be ran at 1.5 ohms so the amps I mentioned would work best for ya.
Username: Boopers
Lima, Ohio
United states
Post Number: 11
how are dvc 6 ohm running at 1.5ohm just out of curiosity, thought they would run at 3 ohm
Houston, TX
Post Number: 447
Yes one will run at 3 ohms and two will run at 1.5 or 6 ohms. I assume since you said visoniks you are meaning a pair. Correct me if im wrong though.
http://jlaudio.com/tutorials/wiring/index.html#2dvcsp
Username: Its_bacon12
Hfl, Ny
Usa
Post Number: 924
two dual 6 ohm subs run completely paralell are a 1.5 ohm load, i would use the bp1200.1, it puts out 1200w rms at 1 through 2 ohms
Username: Boopers
Lima, Ohio
United states
Post Number: 12
ah, I see, didn't think about the bridged output cutting the 3 ohms in half, what do those amps run cost wise by chance
Houston, TX
Post Number: 448
Check out ebay but I believe the jbl 1200.1 will be around 300.00 and the kicker a little more. Defintely under 400.00 though.
Username: Boopers
Lima, Ohio
United states
Post Number: 14
like the sound of that, I do have a hook up for a monoblock 800 watt amp, 2 ohm stable, for 200 bucks, think that will do the job ok?
Hfl, Ny
Usa
Post Number: 926
wait...r u running just 1 sub or two?
Username: Boopers
Lima, Ohio
United states
Post Number: 15
2 subs
Houston, TX
Post Number: 449
No becasue that amp wont be stable down to 1.5 ohms so its not gonna work. You will get no power out of that amp at 6 ohms either.
Here you go.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64573&item=5712130398&rd= 1
(only 200.00 BIN. Thats a heck of a price)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5711880153&rd= 1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5711697172&rd= 1&ssPageName=WDVW (older model of above one but all the same specs 345.00 shipped. Pretty good deal also)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5712215569&rd= 1&ssPageName=WDVW (real good prices on this one. 225.00 shipped)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5712122225&rd= 1
If you have the money I would go with either the memphis amp I first listed or the jbl 1200.1 since they are pretty cheap right now.
Username: Boopers
Lima, Ohio
United states
Post Number: 16
weird, the guy is selling the amp is also the guy I'm buying the speakers from, said it'd work with those subs, ever heard of the Shocker speaker? He's the guy that builds them.
Houston, TX
Post Number: 452
Never heard of the shocker speaker but that doesnt mean anything.
Home > Message Board > Car Audio > Amplifiers > Archive through August 03, 2004 > What amp for 12" visonik [ « Previous ] [ Next » ]
