Thread: General Amp Question about Ohms |
333333523523523 Unregistered guest |
| Posted on Tuesday, July 27, 2004 - 09:49 pm: |
My amp has two channels. 100W x 2 @ 4ohm 170W x 2 @ 2ohm 350W x 1 @ 4ohm bridged So say I hook up one 4ohm sub to one of the channels I will be giving it 100W. If I hooked up a 2ohm sub to the one channel I would be giving it 170W. So correct me if im wrong, but when I put 2 - 2ohm subs on my amp is it bridging the output and then spliting it between channels... like 350/2?
Bronze Member Username: Audiophile
OFallon,
MO
Post Number: 85 Registered: Jul-04
| Posted on Tuesday, July 27, 2004 - 10:59 pm: |
err no. Putting 2 2ohm subs on each channel would be giving it 170 to each sub. If you wired the subs in series, to 4 ohms, then you could bridge the output to 350 and it would split the output, but not exactly even. here is a wiring diagram |
NorthWest,
Michigan
Post Number: 4250 Registered: Dec-03
| Posted on Wednesday, July 28, 2004 - 01:27 am: |
well firstly, putting a pair of 2 ohm subs on one channel would only give 170W to each sub if the amp is bridged mono. then it's only 4 ohm stable anyway and you'd get teh same result putting one sub on each of two stereo channels unbridged. if the subs are wired in series, and put on a bridged amp, the power will be evenly divided between the subs.
| Posted on Wednesday, July 28, 2004 - 07:24 am: |
ok...the amp is a Zapco 350. I want to run the 2 ohm Image Dynamics Chameleon set on it. So I would be delivering 170W stereo to each crossover correct? I am just really confused about this amp. I used to own it and I would switch between stereo and mono and the subs would get louder but wouldnt sound as good. Can someone explain this... |
| Posted on Thursday, July 29, 2004 - 03:59 pm: |
Ok no one is replying.. lol All I want to know is.. my amp stereo at 2ohm (170W)? And on a stereo 2 channel amplifier when it says 170W x 2 @ 2ohm, does it mean the channel or final load of the two channels? |
NorthWest,
Michigan
Post Number: 4306 Registered: Dec-03
| Posted on Thursday, July 29, 2004 - 05:53 pm: |
just wire the components with the crossover modules. you'll get 170w x 2 with that amp impedance doesn't drop unless you put two of the same speaker on each channel so that both speakers on one channel are producing the same frequency at the same time. in your case with a mid and a tweeter this won't happen since the crossover will prevent that overlapping.
