Thread: Which amp for two 12' alpine type r's |
New member Username: Dwhite88
Post Number: 2 Registered: Jul-04
| Posted on Tuesday, July 27, 2004 - 05:57 pm: |
I have two Alpine type r's they are the the SWR-1221D model,dual voice coil,2 ohm. They are in a ported box, not sure which amp would be best, i'm willing to spend 300-400 on an amp, any suggestions? |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 436 Registered: Jun-04
| Posted on Tuesday, July 27, 2004 - 08:17 pm: |
If those are dvc 2 ohm subs you can hook it up and show the amp a 2 ohm load. Here are some amps. Kicker 600.1 Xtant A6001T Either one of those amps would work. They are pretty much same quality. The ony thing is with the kicker you will proably get a remote bass control knob included with the amplifier. This will allow you to control the bass from the front seat. So whichever you can get cheaper I would get. You can buy the remote thing for the xtant amp also its just not included with the amp. Check on ebay for both amps. |
Post Number: 3 Registered: Jul-04
| Posted on Tuesday, July 27, 2004 - 08:50 pm: |
thanks man |
Post Number: 4 Registered: Jul-04
| Posted on Tuesday, July 27, 2004 - 08:57 pm: |
would that be the only amp i need,or would that just power the subs?
Houston,
TX
Post Number: 441 Registered: Jun-04
| Posted on Tuesday, July 27, 2004 - 09:56 pm: |
Thats only gonna powe the subs. |
Post Number: 5 Registered: Jul-04
| Posted on Tuesday, July 27, 2004 - 10:07 pm: |
So i would need a seperate amp to power the speakers than?
Houston,
TX
Post Number: 444 Registered: Jun-04
| Posted on Tuesday, July 27, 2004 - 10:46 pm: |
Yes. |
| Posted on Tuesday, July 27, 2004 - 11:19 pm: |
Well, could anyone please tell me what amp would run 2 12' Type R's 4 ohm? im looking at MRD-M500 and JBL 600.1 which one of these or if any better out there for about the same price? plz help |
Houston,
TX
Post Number: 445 Registered: Jun-04
| Posted on Tuesday, July 27, 2004 - 11:24 pm: |
anonymous, If they are the svc 4 ohm take a look at the jbl as you mentioned, xtant A6001T, kicker 600.1. Those will all give you 300 rms per sub at 2 ohms. If those are dvc subs then the jbl is your best bet. |
Silver Member Username: Its_bacon12
Hfl,
Ny
Usa
Post Number: 923 Registered: Dec-03
| Posted on Tuesday, July 27, 2004 - 11:37 pm: |
yep davids is correct |
sinister minister Unregistered guest |
| Posted on Wednesday, July 28, 2004 - 06:32 am: |
if ur looking for class d amps, i would recomend harrison labs. they are really cheap. dollar cost per watt is astounding. 800 whats at 4 ohms for 300 bucks. a lot of top end car audio manufacturers buy parts from them. these guys brought out the first class d amp into the market. as well as the first passive xover and also the first car eq. now get this. they built the first amp for cars ever. this is an electrical engineering company more than anything. they sell all sorts of electronic gear, but u still have to check out their audio products. their site is hlabs.com |
