I just recently purchased 2 Kicker comp 10's and a Kicker DX350 sub amp to run them. My question is about the subs. They are rated at 125 watts rms and the amp is 350 watts in 2 ohms so will they be able to stand up to the power of this amp?? If anyone have any ideas please let me know.
Relevant Product Info
JSD
Posted on Wednesday, December 04, 2002 - 12:18 am:
Yeah man if your subs are 4 ohm wire them paralell and bridge the amp this will make your amp bridged at two ohm stable that is only if your subs are 4 ohm.turn the amp all the way down on the gain control. now turn your system up as loud as it can go before you blow anything. now with it up as loud as you want to take it start to turn up thr gain on your amp go until you hear the subs just starting to distortthen don't turn up the amp any louder. that is just one way to kinda adjust how much power you want to give your subs.
