Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Class T amps?
Author Thread: Class T amps?
Username: Jaydan
Lockport, Ny
Post Number: 11
Through the advise of Glass Wolf I just bought an Avionixx axt 800.2. It says Class T,tripath. Does anyone know how it's different from Class D.
Username: Soccer
Post Number: 248
Should be a bit less efecient, with a bit more quality
Username: Glasswolf
NorthWest, Michigan
Post Number: 4221
a class T amp is essentially the same as a class D.
class T is designed usually to be capable of working full-range as opposed to strictly bass frequencies. Joao summed it up pretty susinctly.
Avionixx amps are more or less class-D, just built a bit better design-wise for the topology.
alan lamore
Class t amps are designed with a digital powersupply making them as efficient as a class D amp with the signal quality of a class AB amp.
This allows for a very high quality signal output without sacrificing the wasted power and heat produced by class AB amps.
Great for hooking up to subs like class D amps, or any mids and highs like class AB amps.
You can find out more from people who realy know their stuff on clubknowledge.com It's free and you get unbiased advice. That's where I found out about this amp and I've loved having it ever since.
Username: Sploosh56
Post Number: 348
http://www.crutchfieldadvisor.com/reviews/20040720/tripath_interview.html
this artice has some stuff on 'em
Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Class T amps? [ « Previous ] [ Next » ]
