Home > Message Board > Car Audio > Amplifiers > Archive through August 03, 2004 > Would a JBL GTO601.1 power a Rockford...
Author Thread: Would a JBL GTO601.1 power a Rockford 10" p3 well?
Username: Suffster
hey guys, i was wondering if you think the JBL GTO601.1 amp would power a 10" P3 well?
Subwoofer Specs:http://www.rockfordfosgate.com/products/ez2rockford/ModelInfo/ModelInfo.asp?Item Key=10063580&CategoryDesc=Punch%20Subwoofers
Amp Specs:http://jbl.com/car/products/product_detail.aspx?prod=GTO601.1&ser=GTS&cat=AMP
just post a reply or message me on AIM "suffy64"
thanks
Username: Davids2004
Houston, TX
Post Number: 396
If the sub is dvc 4 ohm I would say yea. Its gonna give you more power then you need. Just be careful with your gains. Are you going ported or sealed box.
Username: Suffster
yes they are DVC @ 4 ohms and it's in a sealed box
Username: Suffster
or do you guys think this amp would be better?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64572&item=5711006237&tc= photo
i don't know how refurbished amps are, anyone have experience with them?
Username: Suffster
Home > Message Board > Car Audio > Amplifiers > Archive through August 03, 2004 > Would a JBL GTO601.1 power a Rockford... [ « Previous ] [ Next » ]
