Thread: 2 dvc 2 ohm subs @ 4ohm |
Bronze Member Username: Rubbersdown
Tucson,
Az
Usa
Post Number: 20 Registered: Jul-04
| Posted on Sunday, July 25, 2004 - 07:06 pm: |
If I have 2 subs that are DVC, 2 ohm per voice coil is there any way to run them at 4 ohms? |
Silver Member Username: Jayj
Louisiana
Post Number: 390 Registered: May-04
| Posted on Sunday, July 25, 2004 - 08:07 pm: |
Sure wire EACH sub for 4ohms then get a 2 channel amp and hook it up. Heres a diagram. Use option #2 http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs=1&impedance=DVC2x2 |
Tucson,
Az
Usa
Post Number: 22 Registered: Jul-04
| Posted on Sunday, July 25, 2004 - 08:22 pm: |
How about on a Mono amp? |
Louisiana
Post Number: 392 Registered: May-04
| Posted on Sunday, July 25, 2004 - 08:45 pm: |
No you CANNOT use a mono amp with them and get a 4ohm load. You have 3 options for a mono amp. Option #1 0.5ohm load. Option #2 2ohm load. Option #3 8ohm load. The ONLY way you can get a 4ohm load with those subs is to get a 2 channel amp and wire each sub to its own channel. Heres another diagram look at option #2 and check your specs on your amp and see if it is 2ohm stable. Good Luck http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs=2&impedance=DVC2x2 |
