Thread: Help me choose the best amp out of these 6 !!!!HELP !!! |
Bronze Member Username: Rubbersdown
Tucson,
Az
Usa
Post Number: 18 Registered: Jul-04
| Posted on Sunday, July 25, 2004 - 11:49 am: |
My 2 subs are 2ohm DVC, 600watt rms, 1800 watt max these are the amps im looking at, let me know which one you think is best for my situation... Memphis MC1000D, 1100 watts max, 600x1 at 2ohm rms kicker KX1200.1, 600x1 rms at 2ohm, 1200 watts max Jbl BP1200.1, 600x1 rms at 4ohm Directed 1100D, 800x1 rms at 2ohm, 1400 watts max Mtx 1501D, 750x1 rms at 4ohm kicker SX1250.1, 625x1 rms at 2ohm (THE ONLY 2 CHANNEL AMP I HAVE IN HERE): SOUNDSTREAM VGA1600.2 Van Gogh, 2x800 rms at 2 ohm, 1600 watt max Thats what I have been looking at so far, What do you think would be best for my aplication? |
NorthWest,
Michigan
Post Number: 4188 Registered: Dec-03
| Posted on Sunday, July 25, 2004 - 11:56 am: |
Memphis MC1000D - good amp Kicker KX1200.1 - too small JBL BP1200.1 - good amp, no subsonic filter Directed 1100D - not a bad amp. not great. a bit small MTX 1501D - great amp. lots of power Kicker SX1250.1 - too small SOUNDSTREAM VGA1600.2 Van Gogh - adequate power. Not a big fan of soundstream. owned by directed.
Tucson,
Az
Usa
Post Number: 19 Registered: Jul-04
| Posted on Sunday, July 25, 2004 - 12:50 pm: |
So do you think itd be best to go with the mtx 1501D? If my subs rms is 600 and the max is 1800, this mtx amp puts out 750x1 rms at 4 ohms, and the max would be around the 1500 right? running this at 4 ohms would be better SQ then running it at 2 ohms anyways right? and running it at 4 ohms I should still have no problems pushing my 2 subs right? |
Silver Member Username: Jonathan_f
GA
Post Number: 835 Registered: May-04
| Posted on Sunday, July 25, 2004 - 04:42 pm: |
Don't even worry about the max rating. The JBL 1200.1 will give the ideal power, and the MTX will have more power than needed, but will be fine as long as you're careful not to overdrive the subs. Look at the 2 ohm rating of the amp, not the 4 ohm, since you have 2 2 ohm DVC subs. 4 ohm would be ideal, but can't be done with your subs unless you only run one. |
Tucson,
Az
Usa
Post Number: 21 Registered: Jul-04
| Posted on Sunday, July 25, 2004 - 07:09 pm: |
I cant run TWO 2ohm dvc subs at 4ohms? well if that is the case, what amp is the best out of those? |
Silver Member Username: Jayj
Louisiana
Post Number: 391 Registered: May-04
| Posted on Sunday, July 25, 2004 - 08:10 pm: |
Look for a TWO channel. |
Tucson,
Az
Usa
Post Number: 23 Registered: Jul-04
| Posted on Sunday, July 25, 2004 - 08:25 pm: |
JayJ Then what about the soundstream vga1600 van gough? |
Louisiana
Post Number: 393 Registered: May-04
| Posted on Sunday, July 25, 2004 - 09:01 pm: |
Cody if your subs are 600 watts RMS each then you need a 1200 watt RMS amp NOT a 1600. Look around for a 2 channel 1200 watt amp. Also you can look at a SoundStream 1000/1 it will push your subs good. Heres a website where you can get it pretty cheap. http://www.acaraudio.com/product_info.php?manufacturers_id=26&products_id=452 |
paulito Unregistered guest |
| Posted on Wednesday, July 28, 2004 - 09:41 pm: |
i have the same setup and i'm using 2 orion 600 1 at 1 ohm [lots of power] |
NorthWest,
Michigan
Post Number: 4277 Registered: Dec-03
| Posted on Wednesday, July 28, 2004 - 09:51 pm: |
hehe sounds similar to mine. I'm using an orion XTR2250 bridged for each of my RE triple X 12" subs. works nicely.
