Home > Message Board > Car Audio > Amplifiers > Archive through August 03, 2004 > A quick question (i hope a quick answ...
Author Thread: A quick question (i hope a quick answer)
Username: Camaro_kid
On my amp (kinda old) i have low output and high output on the back, for the low it uses RCA cables, but on the high it uses a bunch of different wires, but my low output has a dial in which i can change the level of output on it.....im wondering would the low output with the dial all the way up be the same as the high output? and if im wiring subs to it what sould i go with? low of high............thankyou peoples
please help me
Username: Glasswolf
NorthWest, Michigan
Post Number: 4189
forget the high level inputs. those are for using a stock factory head unit.
they suck.
use low level RCA lines.
the dial is your gain setting.
set it NO higher than half way up.
here are guides on the proper way to set them:
http://p079.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=34.topic
thanx so much glass wolf
Home > Message Board > Car Audio > Amplifiers > Archive through August 03, 2004 > A quick question (i hope a quick answ... [ « Previous ] [ Next » ]
