Thread: 3-ohm loads and good math |
Silver Member Username: Mattl
Bolingbrook,
Illinois
Post Number: 284 Registered: Jun-04
| Posted on Saturday, July 24, 2004 - 10:56 pm: |
Okay, question for you bassophiles. I bought a setup off of someone who needed money and got all (good) paperwork. * (2) JL 12w6 (custom sealed enclosure) * (1) Alpine MR-V12 1505 (150x2 @ 4) * (1) F cap Okay, so the 12w6 are DVC, 6-ohms/coil. So, series coils and parallel subs means a 6-ohm load. OR, parallel-parallel means a 1.5-ohm load. He had this system professionally installed (to the tune of $1400)... but I can't for the life of me figure a "good" way of having them wired that wouldn't be putting undue stress on the amp. Any thoughts? -Matt |
Bolingbrook,
Illinois
Post Number: 285 Registered: Jun-04
| Posted on Saturday, July 24, 2004 - 10:58 pm: |
Oh, forgot to say that if it were wired parallel coils then straight to the amp channels, how does the amp handle the 3-ohm load? -Matt |
NorthWest,
Michigan
Post Number: 4194 Registered: Dec-03
| Posted on Sunday, July 25, 2004 - 12:20 pm: |
3 ohm load. take the 4 ohm rated power, and the 2 ohm rated power, and find the point half way between. there's your 3 ohm power rating.
Silver Member Username: Jonathan_f
GA
Post Number: 836 Registered: May-04
| Posted on Sunday, July 25, 2004 - 04:42 pm: |
Well, since it's a 2 channel, your only option is to hook one sub to each channel and give each channel a 3 ohm load. If the amp doubles it's power at 2 ohms like it should, then each sub will get 225 watts RMS. Strange setup indeed, and underpowering the subs. Are they W6's or W6v2's? |
GA
Post Number: 837 Registered: May-04
| Posted on Sunday, July 25, 2004 - 04:47 pm: |
By the way, the amp will have no trouble handling a 3 ohm load on each channel, since it's stable down to 2 ohms per channel. |
NorthWest,
Michigan
Post Number: 4199 Registered: Dec-03
| Posted on Sunday, July 25, 2004 - 04:57 pm: |
oh yeah. 2 channel amp. *yawn* I wasn't paying much attention. too bored today.
GA
Post Number: 839 Registered: May-04
| Posted on Sunday, July 25, 2004 - 05:22 pm: |
Know what ya mean, lol. |
Bolingbrook,
Illinois
Post Number: 289 Registered: Jun-04
| Posted on Sunday, July 25, 2004 - 08:49 pm: |
I was mostly wondering because I can't recall an amp giving specifics on 3-ohm loads and didn't know if any of the "load-detecting" amps would have a problem dealing with it. They are straight W6s. I've actually got a stockpile of stuff now to sell and didn't want to rip anybody off. Current inventory: * (2) JL 12W6 (in enclosure) * (1) Alpine MRV1505 (I'm replacing a terminal on this one, so won't have it operable for another week or so) * (1) MMats SQ2125 * (1) MMats SQ2150 * (1) Audio Control EQT * (1) Audio Control EQL13 * (2) Infinity Kappa Perfect 10.1 (SVC) Most of it is new (in box). When/if I sell this stuff, I'll be doing my upgrades (either the Focal or Dyn 3-ways). -Matt |
NorthWest,
Michigan
Post Number: 4204 Registered: Dec-03
| Posted on Sunday, July 25, 2004 - 10:30 pm: |
there's no "load detecting." it's simply a matter of ohm's law. voltage is fixed, load is relatively static, current caries based on voltage and load. if the sub is 3 ohms, the amp puts out the corresponding amount of power unless its an amp like the JL slash series with a regulated power supply and output stage. then the amp puts out the same power regardless of load.
NorthWest,
Michigan
Post Number: 4205 Registered: Dec-03
there's no "load detecting." it's simply a matter of ohm's law. voltage is fixed, load is relatively static, current varies based on voltage and load. if the sub is 3 ohms, the amp puts out the corresponding amount of power unless its an amp like the JL slash series with a regulated power supply and output stage. then the amp puts out the same power regardless of load.
