Home > Message Board > Car Audio > Amplifiers > Archive through August 03, 2004 > Amp Problems....
Author Thread: Amp Problems....
Username: Fordtaurusbass
Iowa
United States
I have a Jensen 500 watt amp, and it usually works fine but today it started doing something weird. The Power light turns green and it will work for a split second then it turns to yellow and then to red. It just keeps doing that over and over stopping for a split second on each color. I checked all the connections to it and they appear to be fine, including the ground connection. Can someone please help me out with this problem? Thanx in advance.
Username: Davids2004
Houston, TX
Post Number: 394
Do you have it running at too load of an ohm load? Maybe the amp cant handle the ohm load you are throwing at the amp.
Iowa
United States
No it's running at a 4 ohm load.
Iowa
United States
Home > Message Board > Car Audio > Amplifiers > Archive through August 03, 2004 > Amp Problems.... [ « Previous ] [ Next » ]
