Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through July 02, 2004
  Thread Last Poster Posts Pages Last Post
Harmon-Kardon system behaviorAnonymous2004-07-23  18:04 ET
MMats 2x150Matt Lavallee2004-07-23  12:59 ET
Rear Speaker Location on a Crew Cab Ford SuperdutyMatt Lavallee2004-07-02  11:29 ET
$1-200, $2-300, $3-500, $5-800, $8-1200 and $1200+Matt Lavallee2004-07-02  11:22 ET
Other forums.Matt Lavallee2004-07-02  07:27 ET
Matching Speakers With An AmpMatt Lavallee2004-07-02  00:36 ET
Sony VS6950 6x9 Four Way SpeakersJayJ2004-07-01  17:35 ET
New system design help in Ford wagonBrian W. Kratzer2004-07-01  13:11 ET
'03 Accord Cpe EX tweeter upgradeIpribadi2004-07-01  10:52 ET
Front Speakers only work on hot days...Matt Lavallee2004-06-30  19:17 ET
Speaker help "Audiobahn 8002T"Clayton Campbell2004-06-30  15:33 ET
Component SpeakersJames R. Reade2004-06-30  15:07 ET
Front speakers not working?? help pleasechris haggart2004-06-29  17:49 ET
Speaker cancellation?JeremyC2004-06-29  15:42 ET
Can I combine channel outputs from a head unitJeremyC2004-06-29  14:57 ET
Focal or MB Quart?? (6.5 2 way components)JeremyC2004-06-29  14:52 ET
Good set of componentsJeremyC2004-06-29  11:54 ET
Do I have to have an amp?JeremyC11 2004-06-29  11:43 ET
Speaker Selection. Please Help Everybody Read!!!!!!!!!!!!!!!!JeremyC2004-06-29  11:33 ET
Advise Please - Boston F5s with kicker amp?JeremyC2004-06-29  11:24 ET
Help with my problem please!!!Anonymous2004-06-29  10:41 ET
Wiring problem....totally baffled!ollie n2004-06-28  15:52 ET
What Would You Buy????Jonathan2004-06-28  01:38 ET
2-way, or 3-wayMatt Lavallee16 2004-06-28  01:08 ET
Which components to buy ???Jonathan2004-06-28  01:07 ET
Infinity Perfect 6.1 versus the 5.1sDEMIGOD3313 2004-06-27  20:31 ET
Amp selection helpits_bacon122004-06-27  19:29 ET
Midbass speaker or a sub?newbeee2004-06-27  01:53 ET
CDT CL-62 brand new for $149.99?Shon Gray2004-06-26  17:15 ET
I need to amp up my 6x9's helpMatt Lavallee2004-06-26  09:09 ET
Running components on HU ampMatt Lavallee2004-06-25  07:54 ET
Kappa Perfect 6.1'sMatt Lavallee11 2004-06-25  00:49 ET
Mid-bass instead of sub?Jonathan2004-06-24  22:16 ET
JBL Components (Opinions)Matt Lavallee2004-06-24  21:17 ET
Which is better?Jonathan2004-06-24  20:55 ET
Genesis. Anyone heard of thembert22004-06-24  07:58 ET
How Do u hook up an AMPBrian Goodrich16 2004-06-24  03:20 ET
6.5 Componants JL MB Quart Or Infinity?????Jonathan56 2004-06-23  20:06 ET
A big dilemma!Jamie2004-06-23  15:54 ET
Front and rear kappa 60.5cs or front kappa and kicker midbass in th...Tuan2004-06-22  23:07 ET
4x6 SpeakersJonathan2004-06-22  22:45 ET
Speaker Wiring_I'm ConfusedMatt Lavallee2004-06-22  19:44 ET
How do you replace a 1996 camry door speakersjcb2004-06-22  16:19 ET
2001 infiniti g20Matt Lavallee2004-06-21  16:11 ET
Frequency range for tweeters?its_bacon122004-06-21  12:11 ET
Another question about tweeters (high pass crossover frequency resp...Jonathan2004-06-21  01:03 ET
Waht speakers to get?Matt Lavallee2004-06-20  10:11 ET
Alpine speakers in an rsx....Josh2004-06-19  12:00 ET
Opinions on setup...Jamie2004-06-19  08:24 ET
Convert from 5 1/4 to 6 1/2 ?Bert22004-06-19  06:15 ET
Help! Trouble with new setup! No bass!rec2004-06-18  23:28 ET
POLK MOMO discontinued?Matt Lavallee2004-06-18  23:23 ET
Kove opulent components?josh dell2004-06-18  19:06 ET
Question about speaker selection and amp settingMatt Lavallee10 2004-06-18  15:48 ET
6.5 Component in front, what in rear?Brian Goodrich2004-06-17  01:05 ET
Extra power needed??Kenneth Myers2004-06-16  22:39 ET
6.5 infinity reference component system!!!!Jonathan2004-06-16  21:45 ET
Programming a 471T transmitter for a Viper alarm?pvk2004-06-16  19:14 ET
6.5" speaker help!!!Matt Lavallee2004-06-16  08:23 ET
What are the best components between the best of Infinity and the b...Matt Lavallee2004-06-16  08:20 ET
In - Phase 6x9'sollie n2004-06-15  14:26 ET
THE BEST 6.5'scainer20 2004-06-15  14:19 ET
Newboy. comments on system?Anonymous2004-06-15  07:53 ET
Question: speaker setup, sound good?Brian Goodrich2004-06-13  05:02 ET
MB Quart or JBL? HELP!!!!!!!!!JayJ2004-06-13  03:40 ET
Can I put 6x8's into 6.5? Possible? Help PleaseJonathan2004-06-13  00:51 ET
Do 6x9's really need enclosures?Jonathan2004-06-13  00:42 ET
Speakers cutting outQuentin Burkes2004-06-12  19:35 ET
Advice on 5x7 choicesDoug2004-06-12  17:59 ET
Infinity Reference seriesJonathan2004-06-12  03:22 ET
Towel on SpeakersLoch2004-06-12  03:11 ET
JL Audio VS Infinity 6.5 and or 6X9? DEMIGOD332004-06-12  02:37 ET
Best Component speakersDEMIGOD332004-06-12  02:34 ET
Help a complete amature pleaseJayJ2004-06-11  20:01 ET
Opinions On A SystemJonathan13 2004-06-11  14:59 ET
Cables for my subwoofer installDonald R2004-06-11  14:50 ET
Did I screw up?Loch2004-06-11  04:13 ET
I need help with my soundsystem pleeaaase!!Justin S2004-06-10  13:46 ET
Is this system goodJustin S11 2004-06-10  13:36 ET
Pioneer 6 x 9Luc Perreau17 2004-06-10  04:38 ET
Shark car audio systemswaggy2004-06-09  09:10 ET
Best tweeter placement ???Jonathan32 2004-06-08  23:48 ET
WHat's the diff? (Infinity Components)Jonathan2004-06-08  23:32 ET
Kicker 6.2 or 65.2 components in JettaWahl2004-06-08  23:21 ET
Did I get a good deal for MB Quarts?ladidada2004-06-08  17:36 ET
JBL 6X9 ENCLOSURE VOLUME?Douw Gerbrandt van N2004-06-08  03:57 ET
Custom components (Glasswolf)Anonymous2004-06-07  17:49 ET
Speaker Damage... Donald R2004-06-06  01:04 ET
Need Advice on System (Jonathan/Glasswolf/Anyone Else)osc2004-06-04  19:09 ET
Help wiring speakersscarfas8519 2004-06-04  18:10 ET
Best components to run from a 50x4 headunit???Sher12 2004-06-04  09:39 ET
Determining Speaker SpecsJonathan2004-06-03  23:54 ET
Rear component speakers to recommend?Mike2004-06-03  06:18 ET
Sony XplodeAnonymous36 2004-06-03  04:02 ET
What do you guys think of my setup????adam wright2004-06-03  03:45 ET
Lowpass Crossovers on 6x8's? T J Peterson2004-06-02  20:31 ET
Infinity 62.5I and 1993 Honda Civic HatchAnonymous2004-06-02  17:27 ET
Bummed! Limited Speaker Options. Opinions Please!T J Peterson2004-06-02  12:19 ET
Bose 201 speakers in my Legacy?John Loomis2004-06-02  00:07 ET
Strange speaker problem, need adviceKane2004-06-01  21:12 ET
Closed Closed: New threads not accepted on this page
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through July 02, 2004 [ « Previous ] [ Next » ]
