Thread: Kenwood, Xtant, or JBL? |
New member Username: Amaru
Toronto,
Ontario
Post Number: 6 Registered: Jul-04
| Posted on Friday, July 23, 2004 - 08:31 pm: |
I was wondering which amp would be better to push 2 10" inch Kenwood KFC-W2509 (300w rms each) a. Kenwood KAC-X811D b. jbl 600.1 c. xtant A6001T d. none (specify which plz) let me know ur opinions, thanx. |
Bronze Member Username: Southernrebel
Louisiana
Post Number: 96 Registered: Mar-04
| Posted on Friday, July 23, 2004 - 09:16 pm: |
go w/ the xtant or JBL...i personally have the JBL, great amp at a great price. kenwood ,i believe, isnt quite up to par w/ Xtant and JBL... |
Bronze Member Username: Joe718
Post Number: 35 Registered: May-04
| Posted on Saturday, July 24, 2004 - 12:20 am: |
jbl all the way |
Toronto,
Ontario
Post Number: 7 Registered: Jul-04
| Posted on Saturday, July 24, 2004 - 01:48 pm: |
i am using the amp ina ported box...so jbl would be the best? xtant looks like it has more features... |
Silver Member Username: Jonathan_f
GA
Post Number: 823 Registered: May-04
| Posted on Saturday, July 24, 2004 - 02:35 pm: |
I'd take the Xtant, better sound quality, a little better build quality, and like you said, more features. The JBL would be my next choice. |
Louisiana
Post Number: 98 Registered: Mar-04
| Posted on Saturday, July 24, 2004 - 02:38 pm: |
the only feature the xtant may have that the JBL doesnt is a subsonic filter...and seeing that you are using a ported box you will need a subsonic filter... i dont know the price difference in the xtant and the JBL, but if i'm not mistaken the xtant will cost quite a bit more...the JBL usually runs about $225 shipped and you can get a 20hz highpass FMOD to put on it that will act as a subsonic filter (about $25 more)....this is what have for my Brahma 10" like i said, the JBL BP600.1 is a great amp! |
Toronto,
Ontario
Post Number: 8 Registered: Jul-04
| Posted on Saturday, July 24, 2004 - 06:10 pm: |
Thanx for everyones response. I think i will end up going with the xtant, does anyone know where i can purchase one? other than ebay because the one on ebay will only ship to United States...and the one on ebay.ca wants $500cdn + shipping |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 391 Registered: Jun-04
| Posted on Sunday, July 25, 2004 - 08:45 pm: |
Check out sounddomain. YOu will have to go with the xtant 6.1 which is the same as the xtant A6001T. Try on ebay a place called electronics delivered and see if they will ship to ontario. |
Houston,
TX
Post Number: 392 Registered: Jun-04
| Posted on Sunday, July 25, 2004 - 08:49 pm: |
Yea but I would defintely go with the xtant A6001T or the 6.1. Both are the same amp just the 6.1 is the newer version. I know someone that has the A3001T pushing a JL 15W3 thats 500 rms. That amp only puts out 300 rms and it knocked down his rear view mirror and cracked it. |
Toronto,
Ontario
Post Number: 9 Registered: Jul-04
| Posted on Sunday, July 25, 2004 - 10:57 pm: |
thanx...btw it says electronics delivered doesnt exist on ebay. |
