Thread: Wat Amp Would Be Good For My 2 12" w6AE? |
New member Username: Sinister6910
San Diego,
CA
United States
Post Number: 4 Registered: Jul-04
| Posted on Friday, July 23, 2004 - 12:50 pm: |
I Would Like To Know Wat Amp That Is Not Discontinued Would Be Best For My 2 12" w6AE? |
San Diego,
CA
United States
Post Number: 5 Registered: Jul-04
| Posted on Friday, July 23, 2004 - 01:04 pm: |
Would The JBL GTO601.1 Work For Them? Or Wats The Best For Them |
Unregistered guest |
| Posted on Friday, July 23, 2004 - 08:09 pm: |
i have kenwood kac 7201 250 rms and 460 w max is 800 how i can get the full 800 out put i got 2 ,12 dual coil 1500 watts |
New member Username: Phaseramous
Cudahy,
Ca
Us
Post Number: 10 Registered: Aug-04
| Posted on Wednesday, August 04, 2004 - 08:13 pm: |
If you are interested I have a 2004 punch p8002 rockford fosgate amp with remote punch bass controller, I paid $600 for it but no longer need it since I got an 1100a2 fosgate and a 800a2 also. I am willing to sell it for $400, i tested the amp by bridging it and hooking up one 12' t1 1200 watt fosgate woofer and a 15' hx2 2000watt fosgate woofer and the amp lifted both with no problem. It is 800 at 4 0hm 1600 at 2 ohm's and 2400 peak at 1 ohm. |
