Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > Good Amp For 2 10"AudioBahn 600 Watts...
Author Thread: Good Amp For 2 10"AudioBahn 600 Watts RMS
Username: Onpoint
I was wondering whats is a good amp for a AudioBahn Dual 10" Tuned Bandpass System 600 Watts RMS I just bought it and i was looking at a 1200w Ultra Linear Amp on Ebay here are the specs:
MOSFET Class A/B Circuitry
DC To DC Circuitry
Power / Protection LED
Low / High Level Inputs
Line Level Outputs
Chrome Plated Screw Terminals
Thermal / Short / Overload Proection Circuitry
Variable LPF / HPF Crossover
Adjustable Input Sensitivity
2Ù Stereo Stable
Bridgeable
Tri-Mode Operation
2x 25A Fuses
Frequency Response 20 - 20KHz
S/N Ratio > 90 dB
Dimensions: 10"W x 2-1/2"H x 12"D
1200W Max Power
300W x 2 RMS @ 4Ù
450W x 2 RMS @ 2Ù
600W x 1 RMS @ 4Ù
I was wondering if this is a good deal for $100 or is it just another crappy amp. Also I was looking at Pyle, Legacy,and Cuspid amps As you can see I'm not trying to spend that much money. But I would Apperciate anybody's help or suggestions for a Amp that would be able to power my subs.
Username: Jayj
Louisiana
Post Number: 366
Well since you didn't list the ohm rating of the sub I'm guessing it is 4 ohm DVC?? If so the a JBL600.1 would push it great. They are great amps. All those amps you are looking at are crap. I wouldn't buy ANY of those.
Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > Good Amp For 2 10"AudioBahn 600 Watts... [ « Previous ] [ Next » ]
