Home > Message Board > Car Audio > Accessories > Archive through September 24, 2004 > Can anyone help!!!!!
Author Thread: Can anyone help!!!!!
jeff larno
I just bought my system off my friend, its a Rockford 1500 watt AMP and 2 audio bahn subs 1000 a piece. we hooked it up in my car and nothing worked and it worked just fine in his car, we checked the fuses and moved the ground sevrel times buts still nothing, any advise???
Username: Jayj
Louisiana
Post Number: 364
Well is the amp getting power?? Are there any lights on the amp on?? Also check your remote wire make sure it is attached to the Blue/blue white stripe wire from the head unit. Good Luck
Home > Message Board > Car Audio > Accessories > Archive through September 24, 2004 > Can anyone help!!!!! [ « Previous ] [ Next » ]
