Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > A1800DB power acoustik amp good for 1...
Author Thread: A1800DB power acoustik amp good for 10" fubr subs?
Username: Rubbersdown
Tucson, Az
Usa
Post Number: 9
What amp is good for 2, 10" fubr power acoustik subs? the subs are dvc, 4 ohm
these are the 3 amps I am looking at, please tell me your opinion, if these both suck, please just let me know what amp you think would be good for these subs, Im just learning about this stuff
so bare with me
THESE ARE THE 3 POWER ACOUSTIK AMPS I AM LOOKING AT, they are all power acoustik
Model Ch 4Ohm 2Ohm Rms Max Dimensions
A1800DB 1 600 1100 1400 1800 12.6”x11”x2.3”
A2400DB 1 900 1400 1800 2400 15”x11”x2.3”
A3000DB 1 1100 1800 2300 3000 16.8”x11”x2.3”
Username: Glasswolf
NorthWest, Michigan
Post Number: 4132
personally I don't like power acoustik at all for subs or amps, but you'll want a two channel amp, rated at the sub's RMS power handling @ 2 ohms x 2 channels.
Tucson, Az
Usa
Post Number: 10
Could you recomend a good 2 channel amp with that rms?
Username: Glasswolf
NorthWest, Michigan
Post Number: 4135
what is the RMS rating for each sub
Tucson, Az
Usa
Post Number: 11
each sub has an rms of 600 and a max of 1800
Username: Jayj
Louisiana
Post Number: 370
You could get a Soundstream RUB1000/2 it will push them fine and last longer then the subs also. Wire each sub parallel to its own channel. Good Luck
Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > A1800DB power acoustik amp good for 1... [ « Previous ] [ Next » ]
