Thread: Help with wire gauges |
| Posted on Thursday, July 22, 2004 - 11:04 am: |
I just bought 2 10" sony subs with 1100 watts max and 300 rms powered by a rockford p3001 that's 150x1@4ohmsRMS and 300x1@2ohmsRMS and i need to know what gauge wiring i should get to hook it all up. |
Silver Member Username: Jayj
Louisiana
Post Number: 359 Registered: May-04
| Posted on Thursday, July 22, 2004 - 11:15 am: |
You will need to get an 8 gauge amp kit. www.knukonceptz.com has 8 gauge kits at a very decent price. Good Luck |
Bronze Member Username: Xgrizzlyx
Post Number: 13 Registered: Jul-04
| Posted on Thursday, July 22, 2004 - 02:53 pm: |
http://www.crutchfield.com/installguide/S-2oXMkqe9DTe/cable_gauge.html |
Post Number: 14 Registered: Jul-04
| Posted on Thursday, July 22, 2004 - 03:02 pm: |
also u will need to the fuse rating of the amps and get an inline fuse about + or - 5 of that/or that number. say both amps have a 20 watt fuse u need a in line fuse that is about 35-45, You hook the in line fuse holder about 1' to 2 feet from the battery. Depending on a good mounting postion under the hood, but closer to the 1 foot as possible. SInce u have 2 amps u need a distrubtion block. From the dis block you can use 8 guage wire in most cases. [img]http://akamaipix.crutchfield.com/graphics/infolib/carlib/amp_wiring2.jpg[/img] Reminder--- unhook the negative to your battery first and hook it up last.... |
