Thread: Question for glass |
Silver Member Username: Rswan
Post Number: 194 Registered: Apr-04
| Posted on Wednesday, July 21, 2004 - 04:54 pm: |
i know that its not good to have your bass boost turned all the way up, but the only way that my speaker moves is if my bass boost is all the way up. i have a mtx801d with a jl w6v2 12in. am i going to damage my speaker having my bass boost turned up so much? |
NorthWest,
Michigan
Post Number: 4111 Registered: Dec-03
| Posted on Wednesday, July 21, 2004 - 07:05 pm: |
set gains properly. if you still need the bass boost up that far, you need a stronger amp. I'm not sure what the load is for your setup. how much power are you giving that sub?
Post Number: 196 Registered: Apr-04
| Posted on Wednesday, July 21, 2004 - 07:25 pm: |
well i have it hooked up in parallel so the sub's getting about 500 watts. the amp is running off of a stock hu. does that make a big difference? |
Post Number: 197 Registered: Apr-04
| Posted on Wednesday, July 21, 2004 - 07:27 pm: |
oh yeah its at 2ohms |
NorthWest,
Michigan
Post Number: 4118 Registered: Dec-03
| Posted on Wednesday, July 21, 2004 - 08:21 pm: |
the head unit is your problem. need a stronger line voltage.
Bronze Member Username: Demigod33
Post Number: 94 Registered: Jun-04
| Posted on Thursday, July 22, 2004 - 01:21 am: |
y is it not good to have the boost up to high?
NorthWest,
Michigan
Post Number: 4119 Registered: Dec-03
| Posted on Thursday, July 22, 2004 - 08:32 am: |
it overdrives the amp and causes clipping this in turn causes distortion that causes speaker damage
