Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > Need help with amp
Author Thread: Need help with amp
jim the slim
i have a pair of kewood 12" typhoon subs they are svc 4 ohm. they have a max wattage of 800 and rms of 400. need help to coose an amp. lookong to spend $250 or less.
Username: Davids2004
Houston, TX
Post Number: 382
Take a look at the jbl 600.1. That will give you 300 rms per sub or a kicke kx800.2 which will give you 400 rms per sub.
Evan Acklin
I just got 2 12" subs and a amp...i know how to hook up the subs to the amp but no idea how to hook up the amp. i need help, preferably from davids2004...it sounds like he knows what hes talking about
-thanks
jim the slim
thanx alot!
Username: Its_bacon12
Hfl, Ny
Usa
Post Number: 852
not a kx800.2 because theyre SVC 4 ohm, you'd onyl get about 200w rms to each sub
get some sort of mono amp, MTX thunder801d, JBL bp600.1, hifonics bx750d, kicker kx600.1, phoenix gold tantrum 1200.1 etc...
all put out around 600-800w rms at 2 ohms, all are mono channel amps by the way
jim the slim
ok . i just needed some guidence n what direction to go. i check into those amps. thanx
jim the slim
so if i was to get a 600 rms times 1 at 2 ohm how many watts would i be getting to each sub cuz i would like to get at least the 400 rms to each sub.
Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > Need help with amp [ « Previous ] [ Next » ]
