Thread: I need to know the levels for my amps |
| Posted on Wednesday, July 21, 2004 - 11:14 am: |
My subs sound good but when they start to BUMP they rattle and my friend says check the levels, I got 4 knobs First knob is MAX LEVEL, the next knob is bass boost, third knob is low level and last knob is high level, i know i dont need that one, but i have most of them turned all the way to their fullest and my subs sound like crap, now i know thats the reason but i can't find the right combo for them to sound decent either, thats for the help |
NorthWest,
Michigan
Post Number: 4104 Registered: Dec-03
| Posted on Wednesday, July 21, 2004 - 11:20 am: |
max level is probably your gain. set that NO HIGHER than half way up. Set low level to about 80Hz. I don't know the LPF range for your amp so I can't guess at the position for that. set bass boost to "flat" or minimum. this will only cause clipping.
