Thread: RCA input sensitivity |
Bronze Member Username: Zbruski
Post Number: 45 Registered: Jun-04
| Posted on Wednesday, July 21, 2004 - 10:12 am: |
What happens when you put RCAs with 6.5 volts up to an amp with an input sensitivity of 4 volts or below? |
NorthWest,
Michigan
Post Number: 4106 Registered: Dec-03
| Posted on Wednesday, July 21, 2004 - 11:26 am: |
you overdrive the input stage of the amplifier which will cause the amplifier's input stage to clip and result in distortion. 6.5 volts is probably an RMS measurement though and the actual signal voltage may be a bit lower, so you may be alright with the gains at minimum.
Post Number: 46 Registered: Jun-04
| Posted on Wednesday, July 21, 2004 - 12:18 pm: |
If the amp does clip what do you recommend I use (and who makes a quality unit) between the HU and amp to cut down the signal voltage? |
NorthWest,
Michigan
Post Number: 4113 Registered: Dec-03
| Posted on Wednesday, July 21, 2004 - 07:12 pm: |
you'd just need to use some sort of signal attenuator. I'm sure some company like PAC or FMOD makes them. Probably about $10-20 for them. Personally I'd just build one but that's not something everybodyc an do.
