Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > Need help with the truth
Author Thread: Need help with the truth
J-dub bob
need help. when i went to ebay and looked at the hifonics bx1000d some sellers said it only had 700 watts times 1 at 1 ohm load, others said 1000 watts times 1 at 1 ohm load. which is it?
Username: Its_bacon12
Hfl, Ny
Usa
Post Number: 844
its 1000w rms x1 at 1 ohm
500w rms x1 at 2 ohm
250w rms x1 at 4 ohm
J-dub bob
thanx
Username: Glasswolf
NorthWest, Michigan
Post Number: 4105
well..
theoretically it doubles power at half the load.
realistically you'll lose power to heat when the load decreases, so 700 is probaboly more accurate in real world terms..
either way that's still the power at full output which most people will never approach.
it'll be loud either way.
j-dub bob
ok thanx
Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > Need help with the truth [ « Previous ] [ Next » ]
