Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > Need An Amp..
Author Thread: Need An Amp..
I just purchased 4 12" Audiobahn Subs AW1251T, that pump out 800w each, or 1600w a pair, which all four would be 3200. Everything I have consists of Audiobahn (cd player, speakers, subs)..so i'm lookin to find an Audiobahn amp that can power up these babies. Any help is greatly appreciated. Thxs!
Username: Davids2004
Houston, TX
Post Number: 374
I was looking up some info on those subs and they are only 400 rms. All four subs will give you 1200 rms. You can wire all four at 2 ohms. I would get a jbl 1200.1 which will give you 300 rms per sub which would be a perfect match.
http://www.rockfordfosgate.com/rftech/wiringwizard/4_4ohmDVC_2ohm.gif
Alright thxs! Just curious, is there any Audiobahn amp that can power them like the JBL could, or no?
Houston, TX
Post Number: 379
There is but the quality is not gonna be as good as the jbl and its gonna cost more.
http://www.cardomain.com/item/ABNA12001DT
I would get the jbl any day over the audiobahn though.
Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > Need An Amp.. [ « Previous ] [ Next » ]
