Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > Whats The Best Amp For 2 12" Jl W6AE?...
Author Thread: Whats The Best Amp For 2 12" Jl W6AE?
Username: Sinister6910
San Diego, CA
United States
I Would Like To Know Wat The Best Amp for 2 12" w6AE Subs Are? Since I Need An Amp For My Subs.
Username: Davids2004
Houston, TX
Post Number: 376
The subs are 300 rms and dual 6 ohm. You can wire them together for a 1.5 ohm load. Take a look at the jbl 600.1 and that will give you 300 rms per sub.
San Diego, CA
United States
Thanks Alot Does Anyone Else have An opinion?
Houston, TX
Post Number: 383
That amp is proably gonna be your best choice. You only other way of running them is at 6 ohms. You could get a 2 channel amp but would need one that puts out a lot of power at 4 ohms bridged. Say for example you have a 2 channel amp bridged and it puts out 1000 rms at 4 ohms bridged. Well at 8 ohms bridged it would put out lets say 500 rms. So at 6 ohms it would put out roughly 750 rms. So you could get a 2 channel amp but you would need a 2 channel amp that puts out 800 rms when bridged at 4 ohms. This would give you approx 600 rms at 6 ohms. You could take a look at the kicker kx800.2 which would also work for ya.
Houston, TX
Post Number: 384
Here are some that would work for ya.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=48598&item=5710155122&rd= 1&ssPageName=WDVW
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5709957055&rd= 1&ssPageName=WDVW
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=32825&item=5711134813&rd= 1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39737&item=5710989232&rd= 1
If you hurry up you could proably get that 2nd one for a good price.
San Diego, CA
United States
Would the JBL GTO601.1 work for the 2 w6s?
Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > Whats The Best Amp For 2 12" Jl W6AE?... [ « Previous ] [ Next » ]
