Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > Amp? plz help!
Author Thread: Amp? plz help!
Username: Amaru
Toronto, Ontario
hi i got a pair of kenwood 10's (kfc-w2509) for really cheap and id like to know what kind of amp i could push them with. Something with a reasonable price, thanx.
Username: Amaru
Toronto, Ontario
can anyone help me out plz?
Username: Davids2004
Houston, TX
Post Number: 372
Since they are 4 ohm svc you will be running the subs at 2 ohms. They are 350 rms. Either look at the jbl 600.1 or the xtant A6001T. Look for them on ebay. Both amps will be under 300.00 shipped. That xtant has more features then the jbl. If your putting them in a sealed box get either amp if your going ported go with the xtant.
Username: Amaru
Toronto, Ontario
ok, great! i am going for a ported sub setup so ill look into the xtant, any other help would be greatly appreciated!
btw does anyone know anything about these subs, i got them for cheap, are they any good?
Houston, TX
Post Number: 380
Well I dont know much about the subs. But try them out and if you like them then thats great. If you dont like them at least you didnt spend alot of money.
Username: Amaru
Toronto, Ontario
thanx alot davids...does anyone else have an opinion?
Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2004 > Amp? plz help! [ « Previous ] [ Next » ]
