Thread: Best amp? |
| Posted on Monday, July 19, 2004 - 12:40 pm: |
sorry, i dont really know much about car audio...so im wondering if an expert here can help me out... i want to get 1 x S10L7 (kicker) - 4 ohm...which is the most suitable amp i should get with this sub? what about the 2 ohm? and what difference does it make? thanks for any replies |
Silver Member Username: Grmncrsnbr
VA
Post Number: 241 Registered: Jun-04
| Posted on Monday, July 19, 2004 - 12:46 pm: |
with a 2 ohm sub youll usually spend less money on a amp to power it. Find an amp that has the rms rating at the sub at the right ohm rating. then look for it on ebay |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 344 Registered: Jun-04
| Posted on Monday, July 19, 2004 - 08:52 pm: |
If your gonna get one sub get the dvc 4 ohm version. You will be able to wire it at 2 ohms. Take a look at the jbl 600.1 if your going for a sealed box and if your gonna go ported look at the xtant A6001T. Look for both on ebay. Both amps will be under 300.00 bucks and will push that sub very well. |
| Posted on Tuesday, July 20, 2004 - 01:20 pm: |
hmmm...and what would be a good head unit to go with these two? im probably gonna get an alpine..just not sure which model would be best for 1 x S10L7 - 4 ohm + JBL 600.1 sealed. |
VA
Post Number: 249 Registered: Jun-04
| Posted on Tuesday, July 20, 2004 - 01:34 pm: |
find a good alpine itll be fine. and pick an amp to power the subs the amp wont change just because you have a different box type |
| Posted on Tuesday, July 20, 2004 - 01:43 pm: |
yea..i was gonna take davids2004's suggestion and get the jbl 600.1 and wire it at 600 watts RMS @ 2 ohms |
