Thread: Question about impedance risk... |
New member Username: Dentlord
Post Number: 1 Registered: Jul-04
| Posted on Sunday, July 18, 2004 - 11:20 pm: |
I have a Pioneer GM-D510M mono amp that is 2 ohm stable, BUT I want to run 3 4ohm 12" subs in parallel, which would make the impedance 1.33ohms, my question is, what is the likelyhood that the amp will survive this load? Should i even try or is it a guaranteed meltdown? |
Silver Member Username: Jonathan_f
GA
Post Number: 803 Registered: May-04
| Posted on Sunday, July 18, 2004 - 11:37 pm: |
It won't even push them, it will go into protection. No meltdown, but no sound either. |
Post Number: 2 Registered: Jul-04
| Posted on Monday, July 19, 2004 - 09:13 am: |
Ok, thanks, guess it's time to buy a 1 ohm stable amp, need more power anyway, any suggestions?? I have 3 Pioneer premier TS-SW124D 12's (1200W max each) |
