Thread: Setting Gain Correctly |
Silver Member Username: Iamduff_87
Michigan
America!
Post Number: 140 Registered: May-04
| Posted on Sunday, July 18, 2004 - 05:10 pm: |
I read on the JL Audio site how to set the gains by using a AC Voltage Meter and a CD with a sine-wave testtone at 0db reference level at 50Hz. Where could I find a CD like this and how much and where could I find a decent AC Voltage Meter that would work for this reason. Thanks. |
Michigan
America!
Post Number: 141 Registered: May-04
| Posted on Sunday, July 18, 2004 - 05:24 pm: |
also i cannot find a voltage chart like they have for the JLs. is this maybe because i use MTX and they have unregulated power supplies where the power is different between 12v and 14.4v. Well i would use a 2ohm load on the 311d. |
NorthWest,
Michigan
Post Number: 4062 Registered: Dec-03
| Posted on Sunday, July 18, 2004 - 09:16 pm: |
www.iasca.com get the IASCA test CD, or just search around for a CD at a music store that has test tones. an alternative is to use a signal generator which is a device designed to generate test tone wavesines. as for a "true RMS" AC digital multimeter, radio shack sells them for about $50 I believe, or any electronics catalog or on-line sales site that sells DMMs should carry true RMS models that can read AC RMS voltage. I have one of radioshack's top of the line graphing PC-interface models and one from Fluke myself.
