Thread: AnyoneUpForALaugh |
Silver Member Username: Jayj
Louisiana
Post Number: 327 Registered: May-04
| Posted on Saturday, July 17, 2004 - 09:24 pm: |
Hey guys Me and a buddy was looking at amps just now when we ran across this amp. I thought it was so funny that an 1800watt amp only puts out 460watts RMS. Item # : Legacy LA1880 2 Channel 1800 Watt High Speed Bridgeable MOSFET Amplifier List Price: $288.00 2 x 150 Watts RMS @4 Ohms 2 x 230 Watts RMS @2 Ohms 2 x 900 Watts Max Output 1 x 1800 Watts Bridge Mode Polished Chrome Finish w/Plexiglass Panel Soft Turn On/Off Circuit Variable Gain Control Remote Turn On/Off Hi/Low Level Inputs Power On LED Indicator Fully Adjustable Electronic Cross Over Network Remote Control Bass Boost (0-18dB @60Hz) 2 Ohm Stereo Stable Bridgeable Into 4 Ohms MOSFET PWM Power Supplies LED Protection Indicator Frequency Response:10-30 kHz Power Supply Voltage:14.4 VDC/NRG GD (10.5-16V) Maximum Current Draw:40A Dimensions:11.5W ” x 2 ”H x 17 ”L Net Weight:10.3 lbs. And some of these people wonder why we tell them to get new equipment. *laugh* 300 bucks for a 400 watt amp. Thats funny. Sorry but it would have to say JL Audio before I would pay that much for so little power. |
Silver Member Username: Jonathan_f
GA
Post Number: 784 Registered: May-04
| Posted on Saturday, July 17, 2004 - 09:29 pm: |
It probably won't even do that. Maximum current draw is 40A. AB amp, so we'll be nice and say it is 60% efficient. at 14.4V with 40 amps, with a 60% efficiency, it is only capable of 345.6 watts. That's likely never attained. Pitiful. lol, though, 300 bucks? I could do a LOT better. |
Louisiana
Post Number: 328 Registered: May-04
| Posted on Saturday, July 17, 2004 - 11:49 pm: |
LOL your telling me. I wouldn't waste 100 bucks on that crappy amp it prolly last you a month (MAYBE). I just posted this to try and make a point. Why buy something like that and pay that much for it when you could do AWHOLE lot better. Thanks for making it a even better point Jonathan. |
NorthWest,
Michigan
Post Number: 4049 Registered: Dec-03
| Posted on Sunday, July 18, 2004 - 12:39 pm: |
these two specs say it all: 2 x 150 Watts RMS @4 Ohms 2 x 230 Watts RMS @2 Ohms look at the power loss going from 4 ohms to 2 ohms! The better the amp is designed and built, the less you'll lose, and the closer to double the power you'll get at half the load. With this amp, you're barely over 50% for a power increase at half the load.
NorthWest,
Michigan
Post Number: 4050 Registered: Dec-03
| Posted on Sunday, July 18, 2004 - 12:41 pm: |
No idea where they got 1800 watts either it's about 450 watts x 1 @ 4 ohms bridged output (RMS)
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 417 Registered: Apr-04
| Posted on Sunday, July 18, 2004 - 01:13 pm: |
Thats another reason why RMS power is so important to look at, Max Power dont tell you HARDLY nothing |
Silver Member Username: Soccer
Post Number: 228 Registered: Apr-04
| Posted on Tuesday, July 20, 2004 - 06:29 pm: |
Funny, that all audiophiles say Audionote Ongaku is the best amp in the world (tube amp), rated at some 25 W x 2 RMS, with about 500W x 2 peak! Makes you wonder... |
