Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Adjusting the sensitivity on a Cliffo...
Author Thread: Adjusting the sensitivity on a Clifford Matrix RS2.
Username: Lat22
I'm getting frequent false alarms from my recently installed alarm system. The flashing light code tells me that "Zone 2-Instant trigger-a heavier impact detected by shock sensor" caused the alarm. Is there any way to decrease the sensitivity of this shock sensor? I live out in the sticks and don't want to drive three hours to have the installer fix it. Thanks.
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 34
check the owners manual, most cliford shock sensors can be adjusted by the key chain remote. Yes I am serious. The IQ series, came with a water resistant remote, and a programing remote. All it took was a couple of clicks on the programing remote, and you could turn the sensitivity up or down as required.
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Adjusting the sensitivity on a Cliffo... [ « Previous ] [ Next » ]
