Home > Message Board > Car Audio > Amplifiers > Archive through July 15, 2004 > Wat size amp do i need
Author Thread: Wat size amp do i need
Username: Mustang23
Mattawan, Michigan
wat size amp would i need for 2 12 inch subwoofers?
wat size amp would i need for 2 10 inch subwoofers?
if you have an answer please email me at lilplaya1623@aol.com
Username: Davids2004
Houston, TX
Post Number: 302
All depends on the rms wattage of the amps and then that will depend on how you can wire the subs. Need more specs. Need rms on the subs and then if they are dvc or svc and how many ohms are they then we can answer it a little better.
Username: Mustang23
Mattawan, Michigan
The XS-L121P5 12" subwoofer handles up to 350 watts RMS, and works well in sealed or ported enclosures.
Key Features:
five-sided polypropylene cone
rubber surround
frequency response 18-2,000 Hz
power range 90-350 watts RMS
peak power handling 1200 watts
sensitivity 89 dB
top-mount depth 6-5/16"
sealed box volume: 1.0 cubic feet
ported box volume: 1.58
Recommended Q-Logic Box Type: 1, 3
1-year warranty
Username: Mustang23
Mattawan, Michigan
Key Features:
rubber surround
sensitivity 89 dB
Username: Loudnobnoxious
Post Number: 39
sony is not the way to go in car audio. please someone suggest this man something that is around the price of the sony p5 but cheaper. im lazy.
Username: Mustang23
Mattawan, Michigan
wats tha way to go then give me your suggestion
Username: Bdonkersgoed
Ontario
Post Number: 17
I think Alpine is supposed to be awesome for head units (I really like mine!)
As for subs, I am getting an Alpine Type R, altough there are other brands that may be better (but more money).
I am getting the 10" Type R on Ebay for $75US plus $35US shipping. It is a 300W RMS 4ohm DVC Not too bad :-) I'm going to power it with an Alpine MRD-M301 350W RMS @ 2ohms monoblock (single channel) AccuClass D amplifier. By hooking up the 4ohms DVC sub in parallel, the amp will see a 2ohm load and I will maximize it's efficiency.
Hope this helps a little :-)
Regards,
Bryan
Ontario
Post Number: 18
I am getting the 10" Alpine Type R sub on Ebay for $75US plus $35US shipping. It is a 300W RMS 4ohm DVC Not too bad :-) I'm going to power it with an Alpine MRD-M301 350W RMS @ 2ohms monoblock (single channel) AccuClass D amplifier. By hooking up the 4ohms DVC sub in parallel, the amp will see a 2ohm load and I will maximize it's efficiency.
Regards,
Bryan
Houston, TX
Post Number: 304
How much do you want to spend.
Username: Mustang23
Mattawan, Michigan
all together for amp plus subs no more than 600
Houston, TX
Post Number: 312
Here you go.
2 dayton quatro 10s-www.partsexpress.com and search for them
Xtant A3001T-130-150.00 shipped off ebay.
Total under 300.00 for amp and subs.
Houston, TX
Post Number: 313
Or instead of the dayton quatros you could do.
2 Xtant Z104-www.sounddomain.com -90.00 shipped for both subs with the same amp
So with that setup less then 250.00.
Home > Message Board > Car Audio > Amplifiers > Archive through July 15, 2004 > Wat size amp do i need [ « Previous ] [ Next » ]
