Thread: Anyone had trouble w/ this |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 403 Registered: Apr-04
| Posted on Tuesday, July 13, 2004 - 06:19 pm: |
Has anyone had trouble with a Optima Yellow Top (light grey body) Deep Cycle battery in a Honda (CRV). I am going to upgrade but i know Glasswolf said that they work for some cars and not for others. Would i have any problems or should i buy a red top (starter)? |
NorthWest,
Michigan
Post Number: 3939 Registered: Dec-03
| Posted on Tuesday, July 13, 2004 - 07:42 pm: |
you should be ok with the yellow top but they work ideally isolated with a red top of high CCA battery for starting
Tucson,
AZ
Post Number: 404 Registered: Apr-04
| Posted on Tuesday, July 13, 2004 - 07:48 pm: |
Well i was only planning on spending the $130 for the Deep cycle, I am short on cash for two batterys. So do you think it would be ok for the yellow or should i just by a red top. I dont want my car to die- especally in the desert. |
NorthWest,
Michigan
Post Number: 3945 Registered: Dec-03
| Posted on Tuesday, July 13, 2004 - 08:04 pm: |
call Optima and see what they say. they have good support.
Tucson,
AZ
Post Number: 408 Registered: Apr-04
| Posted on Tuesday, July 13, 2004 - 08:27 pm: |
Ok, will do! |
Bronze Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 17 Registered: Jun-04
| Posted on Tuesday, August 10, 2004 - 04:06 pm: |
I had a red top in my 99 S10, and was very happy with it. So if the yellow doesn't pan out, go ahead the red top and I am sure you will be happy. |
Tucson,
AZ
Post Number: 449 Registered: Apr-04
| Posted on Tuesday, August 10, 2004 - 04:48 pm: |
OK, i ordered a yellow top the other day, i will let the group know how it pans out. Optima Battreries are supposed to be the best you can buy. |
Tucson,
AZ
Post Number: 452 Registered: Apr-04
| Posted on Friday, August 13, 2004 - 05:46 pm: |
The Optima Yellow top is working great in the CRV. |
