Thread: Finishin up ma system.....wat amp? wat amp? |
Bronze Member Username: Compton2201
Pleasanton,
Ca
Usa
Post Number: 17 Registered: Jun-04
| Posted on Tuesday, July 13, 2004 - 03:28 pm: |
i startin buildin ma system a few months ago n im near the end, i have my head unit, apline 9827 and my type s speakers r great. The sub i have gotten is a 12inch alpine type R , 300w rms and dual 2-ohm voice coils (item # swr-1221d . The only thing im havin trouble with is findin an amp that will make is hit pretty good. I like listenin to mostly rap and some rock and im jus wonderin wat amp will make it kick. Any input would b great, thanks fellas! |
Silver Member Username: Jamtochristian
Williamsport,
Pennsylvania
USA of course!
Post Number: 110 Registered: Mar-04
| Posted on Tuesday, July 13, 2004 - 03:48 pm: |
I'd go with a Thunder502 from MTX. I mean, to be honest, I can see you're really into the whole Alpine scene, which I like Alpine Head Units, so I can understand where you're coming from. But to be honest, I didn't see any Alpine's that will work with Dual 2 Ohm VC's. But, I would get the Thunder502, wire it with one channel to each voice coil. It'll have a little bit more power than you need... say 20 watts per channel, but its better that way so you don't go running the amp into clipping. Just leave the gains a little lower than what is "optimum output". Should be nice. |
Pleasanton,
Ca
Usa
Post Number: 20 Registered: Jun-04
| Posted on Tuesday, July 13, 2004 - 04:03 pm: |
thanks donald, appreciate that |
