Thread: GlassWolf, Audison or Genesis or Arc amps |
Bronze Member Username: Graeme_k
Somerville,
Victoria
Australia
Post Number: 19 Registered: Jul-04
| Posted on Tuesday, July 13, 2004 - 07:05 am: |
G'Day Buddy I can get hold of Audison, Genesis or Arc amps here in OZ, which one would you go for SQ or should I just stick with the JL audio. All of them are 4 ch 50 to 75 watts per ch to either run the Focal 165W's or the infinity prefect 6.1's thanks in advance for the info regards gk |
NorthWest,
Michigan
Post Number: 3922 Registered: Dec-03
| Posted on Tuesday, July 13, 2004 - 07:24 am: |
See which you like for looks, fit, and application, but the Arc amps are terrific.
