Home > Message Board > Car Audio > Amplifiers > Archive through July 15, 2004 > Is it safe to....?
Author Thread: Is it safe to....?
Username: Jonez788
Post Number: 60
Is it safe to hook up the remote, ground, RCA, and power cables to the amp without having any speakers hooked up? All I want to do is see if the wires are all working and it says "On." Can I do this without damaging the amp?
Username: Gotenisdabomb
Midland, Mi
Usa
Post Number: 10
which speakers the ones from the amp or the head unit
Username: Jonez788
Post Number: 61
The speakers that would go to the amp......there's no speakers at all hooked up to the amp.
Will that damage anything if I turn it on to see if it works?
Username: Pat_l
Tucson, AZ
Post Number: 399
No not at all, all its going to do is suppy the power, the amp probably wont even see the differance if there was speakers there.
Username: Pat_l
Tucson, AZ
Post Number: 400
No wont hurt anything at all
Home > Message Board > Car Audio > Amplifiers > Archive through July 15, 2004 > Is it safe to....? [ « Previous ] [ Next » ]
