Home > Message Board > Car Audio > Amplifiers > Archive through July 15, 2004 > Cooling for an AMP
Author Thread: Cooling for an AMP
Da_Bears
What is the best way to cool an amp so that it will not overheat? I have 2 12" subs in a single box that fills up most of the space in the cab behind the seats, and the amps are mounted against the back wall. Space is max 2" between the sub box and the amps.
Username: Pat_l
Tucson, AZ
Post Number: 378
It sounds to me like the AMPs are mounted vertically which will allow the best cooling. You may want to consider fans but it doesnt sound like there is much room. I would just make sure they are out of an area where sun will shine on it, it also sounds like you have that too. So basically you are getting good cooling where there at unless you have had problems (most likely thats why your posting), other people will have some ideas. By the way i am a big BEAR fan as well.
Home > Message Board > Car Audio > Amplifiers > Archive through July 15, 2004 > Cooling for an AMP [ « Previous ] [ Next » ]
